Bulk water supply
May 17, 2015
48
Washington il
We are replacing our vinyl liner in our 32 gallon l shaped pool and need to know where to get fill water for the pool. Our other option is to use well water to fill the pool. Does anyone hav suggestions on water supply and if well water is ok to use?
Often, pool builders and pool stores have connections to water haulers or do it themselves. You can look on Craigslist under services or even call a local water utility to see if they know anyone. Some volunteer fire departments will haul water.
