Bubbles in pump sight glass
Berger82
70
Richmond, TX
While running the pump on high (90%) the glass is completely filled with water and no bubbles at all, cant even tell theres water in there. While on low (40%) there are a few large bubbles and seems the water level drops just a hair. Is this normal while running the pump on lower speeds or is a leak possible. Pool is coming up on a year old and I want to get anything fixed while under warranty. Thanks
Costas > DownUnder
645
Adelaide | Australia
Here is my pump with air bubbles in it when running at low RPMs. Sometimes the main bubble can be 3 or 4x the size but not much larger than that.
Bubbles clear on the next start due to pump running for 5 mins at a higher prime speed and then they slowly form again over time.
If you have a relatively large air space with water thrashing about, it may indicate a suction side leak.
Berger82
70
Richmond, TX
Yep, that's what mine looks like. Thanks
