BMerrill
360
Ayden, North Carolina
Fiberglass
Hayward Turbo Cell (T-CELL-5)
After a lengthy search found the Hayward bubblers. Then the bad news, the bubblers are designed for a gunite pool and Hayward does not make a fiberglass/ vinyl conversion kit.
Using OmniLogic automation and have the 320 lights.
Looking for a bubbler that is compatible with the 320 lights.
Any help is appreciated.
Yup there's no way to use their bubbler. If you really want the lighted bubbler look what you can do is install an additional light beside a standard bubbler and it will uplight it very similarly as the factory setup is a light next to the pipe opening. Old school way of doing a bubbler was a return jet facing up. Just needs to be piped correctly to allow flow adjustment for height
Thank you Jimmy,
Any other manufacturers bubblers compatible with the colorlogic lights. It’s looks like the Jandy may works, have you used the Jandy bubblers?
