Brushes for pebble finish
Georgia_Pool
Active member
Jun 15, 2019
31
Georgia
Hi,
I have an IG 22,000 gal. pool with NPT StoneScapes mini pebble plaster finish. Are wire brushes safe to use on this mini pebble finish, or should I stick with nylon? This product looks pretty cool, anyone tried it or have another favorite brush you would recommend?
Thanks!
Reactions: SteelBlue
zea3
11,779
Houston, Texas
How old is the finish? Fresh finishes need to stick with nylon the first year. The wall whale is a very efficient brush and would be a good choice for any pool.
Georgia_Pool
Active member
Jun 15, 2019
31
Georgia
The pool is new this year, filled with water on 3 May 2019. I have a Dolphin robotic vacuum and still have pebbles shedding and being sucked into it each time I run it.
zea3
11,779
Houston, Texas
I would definately stick with nylon then. Honestly you should only use a wire brush for stubborn black algae spots, and if you maintain your FC levels you should not develop that problem. Im not sure when the pebbles should stop shedding so you may want to check with your builder. I'll ask a couple of experts for their opinion. @JamesW , @jimmythegreek
Reactions: Georgia_Pool
