Broken pipe inside valve to filter
Oct 23, 2017
22
Houston, Texas
Tree fell on equipment. Pvc pipe leading under valve to filter broke off inside valve. Here are pictures of underside. Is there a way to repair or do we need to replace the valve.
I can’t get a picture of the broken part as it is under the actual valve and can’t get further away. But here is a picture of the valve before the accident. The piece that cracked off is the pvc that I circled, it broke in two places with the one under the valve breaking off inside the underside of the valve. Hope this helps
