Broken Bolt for Ladder Anchor Wedge
Hagefamily
58
I'm trying to identify a replacement part for this wedge that holds in my in-ground pool ladder or should I simply go to the hardware store and find a matching bolt to replace the broken one?
Pictures of the broken bolt & wedge attached.
Bill1974
57
Hauppauge, NY
When you are at the hardware store check to make sure the new bolt is stainless steel. It should be about the same weight as a steel bolt but not magnetic or only slightly. If it's very magnetic it will rust and you will be back
