jetskierg
76
Phoenix, Arizona
hi, just got back from vacation for 3 wks. Gf added chems while I was gone. I now see some stuff sticking to some of the sides and on steps/loveseat. I think its somewhere between faint yellow and faint greenish. I had her putting in MA and liquid chlorine while i was gone.
Test numbers this morning. I really don't want to have to SLAM. Do you think bringing up CYA, then raising FC and lowering PH/TA would do it? thx
FC-.5
CC-0
PH-OVER 8
TA-120
CH-550
CYA-LESS THAN 30
WATER IS 82 degrees.
We are expecting super hot temps this week. 115, 117 and 118 degree range.
jetskierg
76
Phoenix, Arizona
After MA numbers are now ( FC was .5 instead of 1 last time. I did math wrong)
FC-.5
CC-.5
PH-OVER 8
I just added sock with recommended stabilizer. Do I start slam now too or wait until tomorrow to remeasure CYA and then begin slam? I'm worried not adding chlorine now because of the high heat. I will be slamming per mustard algae guidelines.
I reread your post and noticed "Lower the ph first........raise cya to 30..........then SLAM for a couple days and you may get rid of a slight case."
My ph is not lower yet. I added 31oz of MA (31%) as recommended and it stayed the same.
jetskierg
76
Phoenix, Arizona
Last night FC-15 7am FC-12 CC-.5 We did have wind last night that blew some debris into the pool. Another 118 degrees expected today. I am concerned that it seems there is yellow dirt sticking to the sides that doesn't come off with brushing. Should I be using a metal brush? thx
