Brand new Hayward Sand Filter leaking from drain plug
DB4
8
Fresno, ca
Has anyone experienced this? We are so frustrated. Would love to fill it with water, filter media and get it running, but not with the leak! Have hand tightened the cap, thightened it more, but nothing stops the leak. S310S filter.
sktn77a
1,674
Chapel Hill, NC
My Hayward filter has a flat rubber disk seal in the cap. Makr sure this has plenty of silicone on it. On mine, there is a flat on the tank threads, so Teflon tape won't work.
DB4
8
Fresno, ca
Thanks for responding. I have read that the Teflon tape will not work in this instance, I do have an email submitted to Hayward, it appears to be a bad seal, but we certainly don’t want to tear it all apart and ship it back.
It sounds like what we have is the same as yours. Two parts-white plastic screen in the hole, and the cap which has an
orange gasket maybe fitted in the top of the cap. Sure hope we don’t have to take everything apart and ship it back, not to mention our pool needs cleaning badly.
Only 2 pieces, a white plastic screen in the hole, and then the cap which has an orange colored gasket(?) on the inside of the cap lid. Seems like it should have an o-ring, but when we look at the exploded view, and replacement parts, no o-ring is on the diagram.
DB4
8
Fresno, ca
It is a 2 inch hole, so our garden hose washers are too small. We went by a rubber gasket shop, and picked up some closed cell foam to put inside. It stopped the leak, until we ran the prime on the pump, and it was running on full speed. Calling a professional out to check our situation, and Hayward only wants to communicate via email, so cannot talk to anyone there who may have heard of the problem. Thanks for the suggestion.
Texas Splash
Gee, that doesn't speak well for their customer service. New filter, relatively simple issue, can't speak to someone, and have to do work-arounds until "they" can get to you? No Bueno. :(
Curious to see what the final result is.
Hayward Pool
In The Industry
Oct 15, 2014
427
Elizabeth
Not sure of the problem, you can call customer service also at 908-355 7995 to speak with a tech
SX180LA is the kit for this filter. Cap and oring.
DB4
8
Fresno, ca
I called Hayward again, and the customer service gal (after trying to push me back to the retailer) sent a message to tech support. I received a call the next day, and the tech said that the seller probably damaged the drain plug, although it showed no signs of damage at all. But, he said he would send two styles of caps, old and new. We are not too sure what will happen with pulling the cap off to try a new one, as there is filter glass in the tank. For now, we have a bucket under the cap, and are watering the trees ��. Will post happy outcome, I hope!
sarniasunfire1982
3
Sarnia
Put a mirror under the bottom side of the threads on the filter check at the plastic weld line I bet it is cracked, mine is and I am dealing with Hayward over this now, clearly a defect.
DB4
8
Fresno, ca
Oh wow, yes, that would be hard to see. I will do that in the morning. Thanks for the tip. I did look at it with a flash light, but not the underside. I will let you know what I find out!
DB4
8
Fresno, ca
So, went to check on our newborn pool filter this am, bucket of water almost full, took mirror and checked underside, but this is of course with the cap on because the filter is running. Steady stream of water coming out the underside of the cap. Seems like more water comes out when the filter starts up, then subsides during the day. I do have photos, and a short video, but do not know yet if I can post them.
