Both my total alkalinity and my pH seem unstable to me (they're moving around a lot).
chuckles98103
22
Seattle, WA
See attached image that shows my test results for the past few days. A couple of things to note:
  1. my pH keeps drifting up .. such that I'm averaging ~3 TBSP of "pH Decreaser" per day.
  2. my Alkalinity keeps decreasing. Prior to the results I'm attaching it began at ~110 and gradually fell to 80.
  3. my pool is vinyl lined and is ~2,750 gallons total.
Is there something funky going on with those two things (pH and alkalinity)?
I see Calcium Hardness being wonderfully stable (as I expect) and free chlorine falling (exactly as expected).
My chemicals are:
A. Clorox bleach for chlorine​
B. BioGuard Balance Pak 100 Alkalinity Increaser​
C. SpaGuard pH Decreaser​
thanks for any thoughts,
--tom
PS: my columns are: "FC = free chlorine, CC = total chlorine, CH = calcium hardness, TA = total alkalinity, pH = pH, CYA = CYA, Sat. Idx. = Saturation Index, as per the Taylor test kit I use, Temp = Temp"
jimbethesda
258
Austin, TX
Stop increasing your TA unless it goes below 60.
Stop decreasing your PH until it hits 8
When/if you do need to raise TA, just buy this: https://www.amazon.com/Arm-Hammer-Baking-Soda-Lbs/dp/B00HNSJSX2/ref=sr_1_4?keywords=baking+soda&qid=1576030868&sr=8-4&th=1&psc=1 It's the exact same thing you're adding now to increase your TA, but without the pool lingo marketing B.S. additional fee.
When/if you need to lower your PH, use muriatic acid (I buy mine at Home Depot). The stuff you're using adds sulfates to your pool, which might not cause problems, but why add it if you don't need it?
chuckles98103
22
Seattle, WA
thanks Jim, i appreciate the guidance.
three questions:
1. isn't the "ideal" range of total alkalinity 80-120? (and if so, isn't 60 a little low?)
2. isn't the "ideal" range of pH 7.2-7.8? (and if so, isn't 8.0 a little high?)
3. does it matter than my CYA reading is close to zero? (my pool is indoor and has a retractable cover, so it's not exposed to sunlight, nor organic debris blowing ).
mknauss
22,732
Laughlin, NV
'Ideal' TA is that which keeps your pH stable. Typically that is anything over 40 ppm or so.
'Ideal' pH is anything in the 7's. Even low 8's if your CH and TA are low.
CYA not only protects FC from UV degradation but also tempers the harshness of the chlorine. Indoor pools should have 20-30 ppm CYA in them.
chuckles98103
22
Seattle, WA
here's the thing: my pH isn't stable .. it's continually moving up. and so that's sort of the core question .. either (1) why is it moving and/or (2) is there some combination of CH/FC/TA/CYA that'll settle it down?
(it sounds like the guidance is: let it move up .. even to the low 8s .. which is not what my Taylor test kit says).
my CH and TA are high ... suggesting my pH should hold at a value lower than 8.
how can i bump up CYA to the 20-30ppm range? my understanding is that clorox doesn't increase CYA ... so, i'd need to introduce another chemical.
mknauss
22,732
Laughlin, NV
You can use dichlor 'shock' or CYA powder to add CYA. Use Poolmath
You CH is low. In the 200's. Only thing elevated pH does is potentially create a condition that scale can form. A pH of 8 or 8.2 with your low CH and a TA under 80 will not form scale.
aussieta
a high ta will cause the ph to raise
each time you add acid it will lower ph and ta
each time you add alkalinity increaser (aka bicarb soda from box store) it raises your ta which promotes ph to rise
my pool has been stable with ta at 50 and ph at 7.6 and has not moved in 12 months
as mentioned you need to keep ph in the 7.6-7.8 range just add a little acid as required for ph
and ignore ta, unless it gets down to 40 or you ph swings suddenly
Donldson
In The Industry
Jun 12, 2009
3,955
NW Ohio
That you are putting "ideal" in quotes tells me you are already starting to see the problem: the supposed ideal ranges are causing less-than-ideal results.
The short of it is that the numbers in the test kit are just boilerplate numbers found on every test kit, piece of pool equipment, and chemical label. Taylor didn't put any work in to developing them, they just slapped them on and sent them out the door. The truth is that there is no one-size-fits-all TA number, a lot of variables factor in to what TA level creates the most stable pH value. In a larger pool with little aeration and using acidic forms of chlorine (common trichlor tablets are highly acidic) then keeping TA over 100 is usually ideal. In a smaller pool with more aeration and using a pH-neutral chlorine source the TA can and should be kept lower to prevent constant pH rise.
chuckles98103
22
Seattle, WA
this is incredibly helpful. i included that Sat. Idx. number for a reason .. i've been paying close attention to it, because as my pH rises, i get closer and closer to the high end of the recommended saturation index range - and that's allegedly where scale will form.
that's my underlying concern for trying to maintain the pH.
do you recommend i bring the CH up? and if so, to what? my pool isn't made of masonry .. it actually has no contact with stone, concrete, grout, etc .. and so i don't think it's leeching minerals out of anything (but i could be wrong).
(and thank you!)
chuckles98103
22
Seattle, WA
this is really helpful. my pool is small, indoor, and has almost no direct sunlight exposure .. and my sanitizer is clorox.
so i'll let TA fall until it's more like in the 50-60 range and see if that stops my pH drift.
i'll also add in a little CYA to stabilize the free chlorine .. but i'll likely keep this very low, at around 20.
... and yes, i'm using the wrong pH decreaser and TA increaser .. i'll switch. i was told, by my local spa company, when i bought my pool: "You can't use Clorox or Arm & Hammer Baking Soda in your pool because they contain too many random impurities that will end up in your pool .. you have to use only the chemicals we recommend". i switched to Clorox after reading articles on TFP and will let those other [SpaGuard] additives run out then buy baking soda and muriatic acid.
chuckles98103
22
Seattle, WA
Does the label on your Clorox bleach say "Cloromax Technology"?
it does, on the side. (see attached image)
the image of the bleach that's the target of your "Clorox Germicidal Bleach" has the Cloromax logo on the front ... but when i look at it on amazon, it doesn't (the label on the bottle is totally different) .. it says "Now concentrated" with a yellow banner on it:
it looks like the product i'm looking for is "Clorox Germicidal Bleach, Regular"
ajw22
11,223
Northern NJ
Thanks, I will check the link. Clorox often seems to change things and you have to watch closely what you are buying from them.
mknauss
22,732
Laughlin, NV
No. Any Ch high enough to keep your water from foaming is fine. That is normally 50 ppm or so.
mknauss
22,732
Laughlin, NV
Be ware of using the Saturation Index. It is not designed for pool systems. It is for steam boilers
Use CSI -- calculated in Poolmath. See Calcium Saturation Index (CSI) - Trouble Free Pool
jimbethesda
258
Austin, TX
That's a new one. Think of it this way, would you rather put Arm & Hammer baking soda in your pool, or bake with TA increaser! I'll pick the one that is "pure" enough to eat.
chuckles98103
22
Seattle, WA
I went to both Home Depot, Fred Meyer, and Lowe's and found the following:
  1. any/all "Clorox Germicidal Bleach" has Cloromax Technology in it (see image), so i can't use that.
  2. the closest i got to a candidate for "pure bleach" was "Clorox Splashless Formula" (see image) .. but "formula" suggests it has something other than bleach in it (it didn't have a "Cloromax Technology" logo on it, which is good).
  3. the Home Depot product listed on the TFP "Liquid Chlorine" page (HDX 128oz Chlorinating Liquid 3 Pack) is not available anywhere in WA State, according to the folks at Home Depot.
  4. the Lowe's product listed on the TFP "Liquid Chlorine" page (Kem-Tek) is not available.
So that begs the question: what do you 'all recommend for a liquid-bleach equivalent for my pool?
(amazon to the rescue?!?)
mknauss
22,732
Laughlin, NV
Do not use 'Splashless' bleach -- that has polymer in it.
HDX
121 oz. Germicidal Bleach
The Home Depots' in Seattle show availability for this product. It will be located near the cleaning products. Last strength reported was 8.25%.
chuckles98103
22
Seattle, WA
HDX 121 oz. Germicidal Bleach
too bad i didn't have time to swing by Walmart and Costco today .. i could have run the gamut of soulless big-box stores.
i picked some of the HDX Germicidal bleach .. totally appreciate the recommendation.
