Booster Pump plumbing
sugast
49
Dallas, TX
I have a Polaris booster pump for my 280 cleaner. The pump has a small leak where the return line connects to the pump. It's a small leak but it's annoying and causing weeds to grow around my equipment! As you can see from the pictures, my return line is 1 1/2 PVC connected directly to the pump. I don't see a quick connect. Does that mean I have to cut the pipe to disconnect the line? Or should I just use some type of plastic weld, etc. to seal the leak? Thanks
crabboy
649
Suwanee, GA
Polaris wants you to use the soft piping with the quick disconnects for their pump. The pump moves quite a bit when stopping and starting and that can cause problems as it has for you.
I'd cut both ends back and use Polaris' quick disconnects with their rubber hose and tie that into your fixed plumbing. The newer black connects are so much better than the old white ones. They screw on rather than snap, which was next to impossible.
