Bonding the water?
A_kraker99
103
Zeeland MI
Electrician is stuck with the inspector because they want to see the pool water bonded. This is what I found.
The NEC (National Electrical Code) requires that an intentional electrical bond of a minimum conductive surface of 9 square inches be installed in contact with the swimming pool water.
How is this usually done? Isn’t the pump technically bonding to water?
ajw22
22,000
Northern NJ
Pentair Intellichlor IC-60
Pump motor that is bonded is not in contact with pool water.
A bonded light housing can provide the water bond. Otherwise there are water bond devices that can be put in the skimmer.
Jimrahbe
20,170
Bedford, TX
99,
As Allen points out, your pool light niche is connected to your bonding system. It is made with a bonding lug just for this specific reason.
A_kraker99
103
Zeeland MI
Jim,
What do you mean? The Pentair GloBrite lite mentions it does not require bonding. Are you saying the light itself is a bond to the water?it all looks plastic to me.
Jimrahbe
20,170
Bedford, TX
99,
Maybe that is the inspectors problem...
I had wrongly assumed that your light was the standard 10" round pool light with a metal niche or plastic niche with bonding plate..
My mistake... If that is the only light, then you will have to find a different way to bond the water, like Allen linked to above..
Sorry for the confusion,
