Bonding Question.
Scjordan1986
5
Texas
I have a 14x20 Hampton resin pool I just installed. The only connection point to any metal is going to be at the wall seam. I have bought a bonding clamp so I can clamp it to one of the wall seam bolts.
So my only connection points for bonding will be the wall seam, pump motor and bonding plate I installed in the pump filter housing portion. Of course I will have the 8awg going around the pool as well. Will this be good enough?
My last question...do I need to ground my pool pump to my gfci outlet? I have read conflicting things about this. It's a 3 prong 125volt double insulated hydrotools which to me I would not need to.
