Bonding Pool Water
Bama Rambler
24,095
It helps to know what type pool you're talking about. the most universal water bonder is the Perma-Cast P2008. It's put into the plumbing so it will work for either an inground or aboveground pool.
ajw22
19,346
Northern NJ
From Electrical Bonding - Further Reading
  • The pool water must be bonded to the bonding loop with a device like:
    • the Burndy BWB680AGRK Waterbug Pool Water Bonding Kit. You drill a hole through your skimmer and install it there.
    • the Perma-Cast PB2008 Water Bonding Fitting PB-2008 in the pipe going to the pump on a tee fitting
