Bonding Pool Heater - Necessary for AGP?
dbdubb28
90
Tampa
None of my equipment was "bonded", but everything minus the heater is 110. We added the heater about 6 months after having everything else done. It's a Hayward heater and works great. What's the recommendation on bonding these? Keep in mind I don't have anything else "bonded" in the area...
AJ.A
72
NE Ohio
CircuPool Edge-40
Anything metal within a certain distance (not sure of exact distance) of the pool needs to be bonded.
Obviously if you don't already have a bonding grid you need to add that first by burying a copper wire around your pool then bonding the pool, water, pump and if you have a metal ladder.
ajw22
24,960
Northern NJ
Pentair Intellichlor IC-60
All of your pool equipment should be bonded together.
The requirement to bond your equipment to your AGP depends on its size and construction.
Reactions: AJ.A
