Finished up an above ground pool deck made of wood with composite decking. The pool is bonded per regulation (installed last year) but now I’m getting a small shock when I walk on the deck then touch the water. This was never the case before the deck. I believe I may need to bond the pool to the deck to complete the voltage between the 2 objects (pool, pool accessories and deck). I do have an electrician coming by next week, but I was wondering how you would bond a wooden structure? The only metal are joist hangers and anchors in the cement footers. There are no electrical outlets on the deck, and the shocks continue even after the breaker is shut off in the house. Any help would be great.
Thank you
Matt
Thank you
Matt
