Blury vision after swimming
steveb21
248
United Kingdom, England.
Ph 7.2
FC 6 (set using the CYA chart)
Had a good few hours of swimming yesterday - mostly under water with no goggles (eyes open)
This morning my vision is Blury.
What would be the cause? Chlorine reaction?
I’ve washed my eyes out with cool water but still not cleared up.
Goggles is on my no1 list of shopping items to buy today!
Rocket J Squirrel
772
Alamo, CA
pH seems low. I've never had mine down as low as 7.2, so I'm just guessing your eyes might be more comfortable with higher pH. I keep mine in the range 7.4 - 7.7 and target 7.5 - 7.6. If you post a full set of test results, maybe something will become apparent to one of our experts.
steveb21
248
I would usually have ph at 7.4 but thought 7.2 is still acceptable.
As also mentioned I did more than usual under water swimming with no goggles.
Just put a few eye drops in, hopefully things will clear up soon.
LoneWolfArcher
376
Michigan
One thing that happens to me isn't pool related, but I have a habit of in my sleep somehow ending up with one of my eyes pushed into the pillow. Then I have distorted vision sometimes up to a whole day. I've done some googling on it and it is fairly common. So maybe your swimming made you sleep harder and you did something similar? I'm a side sleeper and I think that has something to do with it.
Is it blurry or distorted? If you look at an LED like on a cable box does it look like they is more than one?
PoolGate
4,688
Damascus, MD
To be on the safe side, I'd suggest you have an ophthalmologist take a look. A properly balanced pool should have no effect on healthy eyes.
LoneWolfArcher
376
Michigan
I have related to my post above. They said as long as it corrects itself after a day or two there is should be no real damage to the eye.
