The heater has been running fine till today. Got out and check the filter added some water to the pool but I have a E2 error code on the heat pump. Lowest pressure fault. What should I do ? It’s getting dark the pump is still running on the pool should I keep the water running thur the heat pump? Or shut it down till morning. ?
