Blowing out pool lines -
BKH
13
Melrose, MA
I use an air compressor connected to the pump drain plug to blow out my pool lines. I have always blown out the lines with the multiport set to filter (after draining & cleaning my filter). This year I tried to blow out the lines with the multiport set to recirculate (before draining & cleaning my filter). However, I wasn't able to generate any air pressure through the system, and ended up just doing it the way I always have. I'm just confused as to why I couldn't do it with the multiport set to recirculate? What am I not thinking of?
Thank you!
BKH
13
Melrose, MA
I'm surprised no one replied yet. I read your description a few days ago and honestly I couldn't think of a good reason either. Probably right in front of your faces. Maybe with this :bump: we can get some others to chime in.
Hahaha - I kept thinking maybe I didn't post this correctly!
BKH
13
Melrose, MA
I've too have been waiting on the side lines for a descriptive answer. Has there ever been work on the mpv or possibly a decal replaced that doesn't quite match up with your mpv stops.
No, in fact, I had just been using recirculate to mix in winter chemicals, so I know the MPV is functioning as it should.
wireform
In The Industry
Aug 15, 2017
4,633
Spring Valley, NY
Possibly when going through the filter, then the filter acts like a buffer tank building volume and cfm where as going through recirculate the compressor doesn't quite have the necessary cfm to push a pipe filled with water. Don't know if I'm using the right terminology or if I'm even making sense but seems logical.
Reactions: BKH
BKH
13
Melrose, MA
That's an interesting thought, because it did seem no matter how low or high I set the output pressure, the tank pressure would not build at all - as if the tank was just exhausting the air without being able to build up any pressure.
