I noticed in the past the blocking a jet in my in ground stand-alone spa seems to reduce the flow of the other jets, which seems the opposite of what should happen.
I recently installed eyelets in 3 of my 6 jets (I need a wrench to install the other 3 so was going to do that later) and now when I run into pump at full speed I get a lot of noise at the air intake and the remaining jets don't seem to have as much flow as before, although it's not easy to know for sure. But they do "hiccup" as if there's too much air in it lines.
Any thoughts what I might look at to figure out out? The point of the eyelets was to improve the circulation pattern so my skimmer would work at low RPM. I'm not actually sure if it does yet but so far it seems to have made full RPM worse
