I have a blocked skimmer return. I have tried using CO2 to push it out from the pump intake end, and back to the skimmer. The gas bubbles come out at the skimmer (quite vigorously), but it does not dislodge the blockage. So, when I turn on the pump again, there is very little suction at the skimmer, and very little water coming into the basket at the pump. I can see where the gas may travel through the blockage easier than water...so, whatever this blockage is (a big shout out to my TX live oak trees!), it's not coming loose.
Is it safe to use some sort of plumbing snake that won't damage the PVC pipe? I am feeling I need to get more aggressive.
