Black spot on bottom of pebble tec pool
Dennis88
1
Tucson Az
#1
Hi there,
My in ground Pebble Tec pool is 15 years old. A black spot has appeared at the bottom of the pool. I tried scrubbing and applying chlorine to the spot but nothing has changed so I don't think it is black algae but not really sure ?
I have attached a pictures and hopefully this will be of some help!
Thank you so much,
Dennis
needsajet
4,548
Sydney, NSW, Australia
#2
Welcome to TFP! Good to have you here :)
Try brushing it, then put a trichlor puck on it for 5 minutes. Then brush again, and put the puck over it for another 5 minutes. Then take the puck out of the pool. Check it in a couple hours and see if the dark spot has lightened up.
Don't leave a puck on it any longer or it may lighten the plaster.
