Bestway pool adding SWG
HigginsSasha
5
Dartmouth, NS
I have a best way pool 9 x 18 and it currently has a sand filter. I want to switch to saltwater. I did check out a product call flowclear Chlorinator. What type of pump should I use? Also is Intex compatible with Bestway?
Thank you
zea3
11,762
Houston, Texas
You can use intex equipment with your bestway pool. There is a chance you may need to modify the fittings, most of these pools use either 1.25" or 1.5" plumbing.
