Best way to lower TA with a SWG pool?
bostonpool
106
Worcester, MA
Hi folks:
First year pool owner with 32K gallon, gunite pool with SWG.
All chemistry values are in line with the suggested levels on this site for a plaster pool with SWG....EXCEPT for my TA.
TA should be 60-80 and in reality I'm about 140-150.
I know you can lower TA with muriatic acid. My question is, do I need to aerate to increase PH so I add more Muriatic Acid?
Or will the normal PH rise that I get with my SWG do enough to raise PH?
JohnT
Admin
9,876
SW Indiana
Before you try changing the TA, be sure you have a reason. If pH is difficult to maintain at a low enough level, it might be worth lowering your TA. If pH control isn't a problem, don't worry about TA.
