I usually take our vac out of the pool while swimming, and I've always just closed off the suction line in the plumbing (with the pump on) before removing it. lately though, I've been occasionally getting air stuck in the system while doing so, which has led me to ask (and not really find a clear consensus while searching): what is the optimal way to do this? should I pull the vac and close the line with the pump off instead, or is what I'm doing correct?
