Best Places to Buy Liquid Chlorine
Nissarayna
7
Iowa
New pool owner here, just wanted to add what I found today for liquid bleach. My local Walmart (Northeast Iowa) has a generic 10% for $3.64 for 128oz then our local Farm Fleet had the same for $3.29. Not as cheap maybe as some larger cities but I live in a very small town and closest larger cities are an hour away.
Reactions: splashpad
pink
Active member
May 13, 2020
28
Long Beach, CA
$3.50/gal before tax for 12.5% is the best I could find in a 10 mile radius around east Long Beach. Anyone else around Long Beach/socal have a better price?
0REDSOX7
56
Greensboro, NC
Lowe's Home Improvement in Greensboro, NC had about 75 bottles of the 10% pool essentials as of this morning. I got 5 more just because of all the dumping of my pool water with the 14" of rain over the past ten days, I went through more than I would have liked...
mwemaxxowner
163
Pageland SC
I'm not too far from you, and I've dumped at least that much in the past week. More, I think. I had to dump about a "step"'s worth last night because it was almost running over.
This has kinda been good for me. Our CH and CYA levels are a bit high.
dtrebus
80
Claremore, OK
To echo a previous post (can't find it now) I went to Atwoods and they have bleach (5.25%) for $1.19/gallon. Kind of a pain for more bottles, but its like BOGO compared with 10% bleach at Lowes for $3.98
Dtkokay
305
Houston, Texas
Has anyone tried ordering online from Home Depot and having it delivered to your house? I just placed that type of order for six cases of 3 gallons each (18 gallons total) for $9 per case ($3 per gallon). This is for the HDX Chlorinating Liquid, which is 10% chlorine. HD also charges $9 for delivery, but the convenience is worth it to me, assuming this actually works.
AnnikaC
1
GA
I did this in April, ordered 6 cases for a total of 18 bottles for $9 delivery. It worked out great. I tried to do it again yesterday and only one store, out of 5 nearby HD stores, had 2 cases in stock. These cases were not 3 gallon cases either but 2 gallon cases selling for a dollar cheaper than the 3 bottle case. Def get it while you can.
poolnoobgrandma
417
Seminole, FL
Depending on the pool surface, excess calcium is not desirable. Stabilized pool shock adds more CYA. None of those are good in the long-term or frequent usage
I don't have high CH, and rely on my SWG for most of my chlorine needs. At the beginning of the COVID-19 situation, I ordered a bunch of cal hypo in powdered form to have on hand. I've used that when our chlorine needed a bump with no ill effects. We were able to get Home Depot contactless pick up of their liquid chlorine later, and will use that when needed now. With the powder it takes a little longer to be crystal clear.
DanF
190
Chandler, AZ
Seems like a good idea, but I have a few questions: Don't you folks worry about the chlorine deterioration with that quantity? Especially if HD stores it outside prior to delivery? Where do you folks store the jugs while at home? Are you able to see the manufacturer date prior to ordering?
Oly
1,624
Fresno, CA
Yes two packs at HD here as well all 2 months old and they raised the price nearly $2. Now supply has dwindled. I have located 12.5% in returnable bottles in 4 gal totes for $18 at a small local pool supply store. So far so good.
Reactions: DanF and splashpad
