Best chlorine test kit.
MA5177
134
Phoenix, AZ
The Taylor 1000 kit that that came with my TF test kit is pretty basic( yes I know I can do the powder test in the TF kit) but that is time consuming and I figure I will only use that to check for CC. The 1000 kit only goes to 5, is there another kit that goes to 10?
ajw22
26,598
Northern NJ
Pentair Intellichlor IC-60
Nope, that is why you have the FAS/DPD test. Use it. It takes less then 5 minuted to do a FAS/DPD chlorine test. Fill the vial with 10ml of water, dump some power in to get it red, count the drops tile clear, and you are done.
Reactions: MA5177
MA5177
134
Phoenix, AZ
I guess since my FC needs to be between 4-6 I can just eyeball it, I will do the full test once a week
ajw22
26,598
Northern NJ
I hope your eyeballs are well calibrated.
Good luck.
Reactions: Kevinr14
YippeeSkippy
17,100
Evans, Georgia
Most of us only use that basic comparitor block tester to tell us if our hot tubs have *any* chlorine in them (the value isn't important) versus *no* chlorine. But with a pool you want to know if your FC is high enough based on your CYA, and if you have CC (cooties) in the water. That comparitor block can't tell you that.
MA5177
134
Phoenix, AZ
But it reads up to 5, 5 is where my chlorine should be at. So if it’s darker than 5 not to worry correct? I mean chlorine and PH fluctuates so fast
YippeeSkippy
17,100
Evans, Georgia
My pool may only need "5ppm" but I always add a couple more ppm to allow the sun to burn off its daily tax and still leave me with my necessary "5ppm" :)
MA5177
134
Phoenix, AZ
Good luck.
I tested both ways today... on the OTO test showed 4. I tested the hard way and came out the same 4. The OTO doesn’t have a 4 but was darker than 3 and lighter than 5.
Close enough for me I’m going to try to keep at 5 plus until I go salt.
Oly
2,142
Fresno, CA
Yes! This is the wonder of knowing your pool, knowing how to test the water, understanding the water chemistry and knowing the effects of pool chemical additions. You become free to make your own educated decisions for your pool system. Power to the pool owner. :rockon:
I've always wanted to use that smilie.
Prickly
127
Kelowna
Fiberglass
Hayward Aqua Rite (T-9)
I use the Lamotte colour q pro for my daily chlorine and pH tests because it is much quicker and the results are exactly the same as my Taylor fas-dpd but with a quick digital reading and no pH colour matching for my bad eyes.
I have the Taylor for the other tests that I do less frequently (cya, TA and CH) as the Colour q is not great for those.
Some people say there is high error with the Lamotte. This is likely user error as the test tubes are tiny so if you don't fill them precisely and hold your dropper vertically you are can really throw off your results. With careful use it's great and does read to 10 ppm chlorine.
Reactions: MA5177
jseyfert3
1,676
Southern WI
Do you have the SpeedStir? I can do the full FC/CC test in under a minute for typical FC ranges. If you don’t need CC skip the last part and it’s even faster.
Fun fact the pink portion of the test can actually be a color comparison test, and the DPD comparator block goes to 10, but on quick look it appears those kits come with liquid DPD, unsure if the powder works the same. In any case you could get it if you’re good at differentiating shades of pink.
Reactions: markayash
markayash
3,323
Atlanta Ga
I didn't know that about the pink but have got pretty good at guessing the FC by how dark pink it gets :)
mgtfp
1,026
Melbourne, Australia
Astral VX 7T
The OTO test is not an FC test, but a TC test. As Maddie said, it's great as a quick yes/no test, or a sanity check when you think that your FAS/DPD might be expired.
markayash
3,323
Atlanta Ga
Dont they made a "bigger" version of the 1000 that read levels up to 10 instead of 5? Saw it on here once but could never find it online
MA5177
134
Phoenix, AZ
Looks like you have some CC
  • Haha
Reactions: YippeeSkippy
