baquacil with CDX to chlorine
wildkatt
9
cleveland oh
Have been using baquacil w/ cdx for 5 yeras. For the first time, opened pool and cloudy white on Friday. Added startup chemicals, Vaccumed and ran filter for 48 hours, no help. I put in floc toda (Monday), need to wait 24 hours to see if helps, but read on line this condition almost impossible to clear up with Baquacil. So planning to convert to chlorine. 24 foot pool, about 15,ooo gallons. I live in Ohio, alot of rain in forcast. Questions: How much bleach should i have on hand to convert? Also since I'm at work during day, I cant check evry couple hours to keep it to the magic number of 15ppm. I will check in morning before I leave. How will this affect my conversion?? I'm so scared.
mknauss
32,962
Laughlin, NV
Welcome to the forum!
With CDX, the consensus is to do as large a drain and refill of the pool as you can. Once you tell us more about your pool we can guide you on that.
wildkatt
9
cleveland oh
mknauss
32,962
Laughlin, NV
Get a sump pump and hose and determine where you can drain to. Pump out leaving 18" or so of water and refill. That will help you tremendously.
Reactions: wildkatt
wildkatt
9
cleveland oh
i just went to store to check availability of bleach, doesn't seem like a problem, no limits and $3/gallon. I see another member here started of her conversion with the calcium hypochlorite shock, so i bought some of that as well, knowing I'll probably need at some point anyway. I'm am going to drain about half of water out of pool and refill before I begin. Should I start my conversion off with the shock, or just use bleach?
mknauss
32,962
Laughlin, NV
Just use bleach. The Cal Hypo is fine to use later but you do not need calcium in your water as you have a vinyl liner. If you use Cal Hypo, be very sure it is fully dissolved as it can stain your liner.
