Balancing Water after Liner Replacement
dmpoole
9
Burkburnett, Texas
I am having my vinyl pool liner replaced this week, the old one was 12 years old. I have a SWG and cartridge filter. My contractor wants $800 to balance the pool after the liner is installed . Does this make sense, or should I just do it myself.
I have tested my fill water:
Chlorine - 0
PH - 7.6
Total Alkalinity - 180
CYA - 0
Salt - I do not have the chemicals to test this
Mdragger88
2,506
Hernando, Ms
Intex Krystal Clear
whoa! Thats alot of dough$$
What test kit do u have ?
You can order a salt test on tftestkits & it would probably come in a few days
(which is pretty necessary to maintain a salt pool)
You will need to dose w/ liquid chlorine daily until your salt is dissolved & swg is up & running.
Recommended Levels
PoolMath should be able to tell u what u need to add but your fill ph & alk look fine.
Chlorine is paramount
Mdragger88
2,506
Hernando, Ms
Intex Krystal Clear
$75 stabilizer (20lb) total -add it in stages like 75% then test
$180 salt (1100 lb) total - add it in stages like 75% then test
$20 10% bleach (5 gal)total- add daily according to FC/CYA Chart
$35 salt kit w/shipping
$13 muriatic acid (2gal) which u may or may not need right now but will probably last u at least a season.
So about $323 worth of stuff give or take.
& almost $500 for him to dump it in & walk off.
mknauss
41,875
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
How did you test that salinity? Seems high for domestic water in your area of Texas. You can use that for your starting point and once you get to ~3000 ppm (what SWCG do you have?) then just make the SWCG happy so it operates.
