Balancing new pool
Cavmedic
68
Seminole, Florida
I had to add 4 lbs of stabilizer. Basically a jug of the Clorox pool and spa stabilizer just to get it up to 70. Still have some to go but getting there.
New pool here also.
I am now at:
FC = 7 (target 6)
ph = 7.3 (pretty good but will have to lower to bring down TA)
TA = 100 (target 80)
CH = 200 (was told by builder to leave alone for a year)
CYA = 70 (target 80)
I am debating the borates when I get this dialed in.
SWCG Pools
CYA (Stabilizer)Minimum FCTarget FCSLAM FC
60*3424
703528
804631
* Not recommended
ajw22
12,878
Northern NJ
CYA 70 is fine this time of year. Wait and see what your FC loss is as you get into the summer With CYA 70.
pH of 7.3 is fine. Your TA will come down as you lower ph due to the normal new plaster rise.
Targets should be ranges not a specific number. Anywhere in the range is ok.
Cavmedic
68
Seminole, Florida
Thank you for the insight.
I am still trying to find the sweet spot for the SWG.
