Balancing New Pool Water
dlwxman
122
Atlanta, GA
It's been 11 years since I've balanced new pool water but we just installed a new pool liner and refilled the pool. Please refresh my memory on what order I should add the products in order to balance properly.
mknauss
33,967
Laughlin, NV
Get a baseline of your fill water pH, CH, and TA.
Add chlorine to 3 ppm FC.
Start dissolving 30 ppm worth of CYA using the sock method.
Test pH and adjust into the 7's.
Follow the FC/CYA Chart
dlwxman
122
Atlanta, GA
Thank you! Exactly what I needed. Just one more thing. With a vinyl liner, I've never paid much attention to CH. I've seen differing views of that at TFP.
mknauss
33,967
Laughlin, NV
Low CH is of no consequence to you as you do not have a heater. As you have not entered your Location, I was not sure if you may have high CH fill water.
