Balancing Help
mknauss
34,573
Laughlin, NV
I just started reading about ozone systems. Should it turn mine off? Not even sure how to do that.
They do consume a small amount of chlorine. But it should not be significant. The systems used in residential pools are so small they are of no real value. Removing it completely and not using any more electricity for it is the best move.
Jbthompson
51
Texas
Ok quick question. I am planning on doing an overnight test tonight. I have been testing every three hours today. I added 2 gallons of chlorine around 1145, and around 2 tested again and needed to add three gallons which seems like a lot. I did it, but is losing that many ppm (went from 16 to 6.5) in three hours normal? It is 106 today and my pool is in direct sunlight. Water looks beautiful.
mknauss
34,573
Laughlin, NV
At the FC level for a SLAM you will lose a bit more chlorine to the UV of the sun. But most is being consumed by organics.
As long as the water is crystal clear and you are not getting any dead algae build up on the pool floor, do a OCLT tonight if you wish. I suspect you will need follow the SLAM Process for a few days however.
Reactions: duade
Jbthompson
51
Texas
Ok question. So today I went back to work and wasn't able to test the pool until 5pm. I also just realized I am out of bleach and won't be able to get any until tomorrow evening. Did I just ruin the SLAM process? I think I am really close, this has taken more bleach that I ever thought it would and I thought I had another box but it was empty.
Jbthompson
51
Texas
It may set you back a day or two.
Ok thanks. How long does this usually take? I did it solidly thursday night through Monday morning and I've gone through probably 40 gallons of bleach. I am just at work the rest of the week 9-5ish which makes testing regularly a little tougher.
mknauss
34,573
Laughlin, NV
If just cloudy and no visible algae, a few days. If algae and green, a week or two. What filter type do you have? Your signature just says Pentair Filter.
Jbthompson
51
Texas
the water is crystal clear. I am seeing dead algae (at least I think that’s what it is) on the bottom of the pool. Might be dirt. I have a Pentair cartridge filter.
mknauss
34,573
Laughlin, NV
Check all hiding places. If you are seeing dead algae then you still have live algae.
Cartridge filter will clear pretty well. Be sure to clean when you get a 25% rise in filter pressure over clean pressure.
Jbthompson
51
Texas
Ok will do. The filters got cleaned a month or so ago and pressure looks good. Will keep an eye on that for sure. The water looks better than it ever has.
Jbthompson
51
Texas
Hi there. Ok my pool passed the overnight test. Water is clear. This morning I measured the pool at 20ppm. I got home at five and just measured and the pool is at 2.5ppm. How could I loose that much chlorine in 9ish hours??
mknauss
34,573
Laughlin, NV
Are you still following the SLAM Process? If so, then yes, it could have dropped that far. I did not look back at your thread. You need to check and add chlorine more often or the SLAM can take a very long time.
Jbthompson
51
Texas
Maybe not.
bummer. I am struggling with this, should I not continue if I can’t test more regularly? I am just out of the house 8-5 during the week.
I just don’t understand how the pool can hold the chlorine overnight and then lose almost all of it in 8 hours in the sun.
