I’m trying to balance my chlorine and the trade off is the percentage setting on the SWG versus running the pump. Is there a preferred method? I’m thinking a lower percentage on the SWG and running the pump more often. I have a VSP so running the pump a lot would not cost much if I run it on medium or a bit less. Which brings up another question. Does the SWG produce less chlorine if the pump is running at a slower speed? I’m thinking it wouldn’t matter as long as it’s flowing enough to allow the SWG to generate.
This is coming up because while I was doing pretty good running my pump for 8 hours with the SWG at 50%, the heat has now come (with a lot of sun) and that balance isn’t cutting it. I ran a super chlorinate last night to get the chlorine back up. So I’m thinking that running the pump at night is best since it makes sure the chlorine is there when the sun comes up rather than trying to play catch-up all day.
Anyway, how do you balance the settings in the hot part of the year?
