Balanced, now what
Macuick
18
MS
It's been a few years since I had a pool. I just installed a 27' Round by 54" semi-inground pool. I know the most important is balancing, which I have already balanced. Anything else other than maintenance?
Melissa, Waveland, MS
27'x54" round, semi-inground, vinyl, aluminum walls, approx 19k galllons, chlorine, 27" Millenium sand filter, 2.0 hp 2 speed pump, Waveland, MS
triptyx
1,512
Welcome to TFP! Keep a careful watch on your chlorine, using daily testing and additions of a non-stabilized plain bleach or liquid chlorine, or if you're using tablets ensure you're adjusting your free chlorine upwards as the CYA rises over time. Other than that, enjoy your pool and keep an eye on those numbers. :)
So, since you're newly back to pools, do you have a complete test kit that can test for free and combined chlorine, pH, total alkalinity, calcium, and cyanuric acid? What did you do to establish that the pool is balanced? Do you have a full set of test numbers you can share?
While we wait, if you haven't seen them already, here are a couple of good articles for you to review if you haven't seen them already:
Macuick
18
MS
fcl 3; tcl 3; alk 160 (could be a little lower but ph is 7.8) hardness is low; cya is 40 Tested with Hydro tool by swimline test strips, the pool place suggested in 2 weeks to add calcium Is this a good testing system?
triptyx
1,512
Test strips give you ranges, they're also usually very poorly quality controlled and their numbers are extremely inaccurate. We call them "guess strips" since they're really just a guess.
There's a good article here on test kits that list the various types that we recommend. It's very important to have a good test kit!
As for calcium. There's little reason to add calcium to a vinyl pool. You do want a little, but since there is no plaster to be concerned with, you don't need usually to add much above what is already in your fill water. Recommended levels for that for a vinyl pool are around 50-550, the lower end is a good idea to restrict scaling. You can see other recommended levels here:
woodyp
11,234
East Texas
Use the test strips as fire starter and order yourself a TF100 from TFTestkits.net You can thank us later!
  • Haha
Reactions: triptyx
