Got home today and saw that the builders laid the coping today.
All around the pool the gap between the coping and the deck is different widths because the had to lay a lot of them cockeyed to make them fit. There are some places with huge gaps on the pool side and the pieces butting up against each other on the deck side, or vice versa on other pieces. There are pieces where the radius is clearly wrong so the ends have a small gap between the deck and the coping, but the center has a huge gap. Some pieces aren't even lined up.
On the spa they cut one of the pieces into two smaller pieces. Probably because it was so out of whack they couldn't even fit it by making it sit cockeyed. It looks bad having all these same length pieces of coping and then two little ones in one spot.
In my opinion it's not a very good job. I think I'm going to have them stop work until they can figure out how to make it better. Am I being unreasonable?
See pics.
See pics.
