Backwash Valve "Exploded...?"
fatboy1271
We're remodeling our kitchen and haven't been home much lately. This has meant that I've unfortunately neglected my pool. Anyway, I came home last Sunday and found part of the PVC coming from the backwash valve about 3 feet away from the filter. The pump and SWG weren't running at the time, so I quickly put the pump in stop mode and took off the On switch for the SWG timer.
My gardener apparently saw the PVC on the ground and water leaking from the filter housing; yet, he didn't bother to contact me to see if I knew about it :| This means that it had happened Friday night or earlier and like I said I didn't see it until Sunday; therefore, the pump ran for at least two nights spewing water all over the place. I do have an auto-fill so the water is at its minimum level at this point.
I was thinking of replacing the backwash valve and PVC myself. I'm now a little intimidated to do so because it seems pretty obvious that a tree branch didn't cause this, but more like there may have been too much pressure and it blew apart the PVC. Any thoughts on doing this myself versus hiring someone? If I hire someone are there specific questions I should ask?
Thanks for reading and any help is greatly appreciated!
Patrick
mknauss
23,065
Laughlin, NV
It is hard to believe that over pressure did that unless the PVC was tremendously weakened due to long term exposure to UV. But who knows.
It would be better to use a MPV rather than a bump valve.
Let's see what some other members have to say.
Reactions: fatboy1271
JoyfulNoise
Platinum Supporter
May 23, 2015
16,133
Maybe “the gardener” knows more than he’s letting on 🤨 Not impossible for that part to blow up but it would require the pump running at fairly high speed AND there would have to be something plugging up that pipe.
Have you taken the filter apart? Something is not working right and a more in depth investigation is needed.
Jimrahbe
15,415
Bedford, TX
1271,
I agree with Marty about this not being an over pressure issue, other than the push/pull valve was old and the PVC was just brittle.
Personally, I don't see much of an improvement by going with an MVP valve..
I would for sure open the filter and make sure everything is clean inside.
I am done with DE.. I have two rent house pools that currently have DE filters and MVP valves.. When they die, they will both be replaced with large cartridge filters and no valves between the filter and the pump.
ajw22
11,848
Northern NJ
An "explosion" would have burst open the PVC at one point. An over pressure would have burst the pipe at a weak point.
Something hit the pipe to crack that length off and find it laying on the ground.
JJ_Tex
617
Prosper, TX (DFW)
It looks like something physically broke the pipe.
Does the gardener trim the ivy on that back wall? Was it done recently?
Did your kitchen remodel involve taking large items like counter tops, appliances, etc by the pool equipment?
Could someone have been trying to climb the wall? If someone was climbing the wall, the natural place to step would be on top of that pipe and could easily cause the damage.
Newdude
1,678
NY
I’m with JJ. How high is that wall ? Chances are your gardener is like the gardeners by me...... short.
If you put the piece back the way it belongs, you’ll see that the way it broke was pushed hard from the wall towards the yard. Both ends of the pipe match that direction. If it exploded it would have pushed the whole thing towards the right and whichever way it forced the PVC pipe would have broke the other half of the other end.
fatboy1271
Thanks all for the replies! Busy weekend but I will try to open up the filter housing and see what it looks like inside.
My gardener is not short, haha, and I don't want to blame him for this, but it sure seems odd... Especially since he'd assume that I knew it was broken when it clearly hadn't been looked at.
All of the kitchen remodel work has been done well away from the pool equipment so I don't think I have any reason to suspect them.
What's an MVP versus a Backwash Valve?
mknauss
23,065
Laughlin, NV
You would need to call them for the one that would work with your DE filter.
MPV is a Multi Port Valve.
JamesW
17,026
A multiport is much better than a slide valve.
You need to make sure that the SWG can't run with the pump off.
The gas probably built up in the highest part of the plumbing and exploded.
JamesW
17,026
You can run the SWG on a timer set within the operating window of the pump.
You need to replace the valve in any case. So, I would go with a multiport.
JamesW
17,026
Maybe put the SWG timer 30 minutes inside the window on both sides for safety.
I would go with a 2" multiport valve.
Also, check the pump lid. It might be on backwards. It should be labeled "Front" for the front of the lid.
