Hi all. I am a relatively new pool owner. Purchased a home with salt water pool in May of 2017. The pool and equipment are 10+ years old, not sure of actual age. We've had relatively few issues over the last four years (had to replace a filter pump motor), but now have several issues in a short time period. We have a pool tech from a reputable pool company, but have still had to figure out most things on our own. The tech that comes out regularly is really just here to clean the pool and take care of regular maintenance, anything more than that and we have to engage the owner. The issues started end of winter/early spring with the Jandy control panel fuses repeated blowing. My pool tech kept changing the fuses, but they would just blow again and he could never figure out the issue. Well, they stopped blowing out when the sheer descent would not close and I figured out with the help of reading through these boards that the actuator was clearly going bad causing the fuses to blow and they stopped blowing when it ultimately died, so we switched out the actuator and sheer descent started working and no more blown fuses. Fast forward to late Spring and the control panel on the pool heater went out. I bought a new control panel, switched it out myself, and everything working properly again. A week after replacing the pool heater, the tech advised that the AquaPure had failed. I ordered a new one online. It took a couple weeks to be processed and delivered and our tech installed it last week on his regular rotation. Well, we haven't gone in the pool since then, but I decided to check the pool temperature with the app today. After turning the pump on, I never received a reading so I went into the "web" version and it says that the sensors are "Open". The web also says AquaPure 0%; Salt 1400 PPM; Check AquaPure; (Low Salt). So I text the owner that I think that all of these issues are related, I don't think the AquaPure is set up properly, and why are the sensors open? He responds that "open" means the sensor is broken and needs to be replaced, that this all was probably the result of a lightning strike and we're figuring out the issues one by one and that the AquaPure is set to 100%. Can I please get your thoughts? Specifically, I want to understand if replacing the AquaPure could cause the sensors to go out, whether all of this is potentially related or just a coincidence that everything is going out about the same time, and whether the AquaPure is actually set up correctly. Thanks!
