Average enclosure height?
Zamsaf
100
Orlando/FL
Hello. After my pool is done the PB is installing a 10ft pool enclosure. Is that an average height? I would ideally like it 1-2 feet higher but not sure what most screen enclosures height are. Will the 2 feet make a difference? I have a two story home the 10 ft comes right about the middle of the house.
sktn77a
1,589
Chapel Hill, NC
10 feet seems pretty low (unless it curves up/peaks higher in the center). Get what you want - it may cost a smidge more but after its done, its too late!
jtburf
481
Houston, TX
Most likely that is the wall section height, google enclosueres and you can see most are in the 10ft wall then peak between 17-20ft.
John
Pprior
46
Englewood, FL
Well it's going to end up attaching to the back of your house, so how tall is that? That will be one wall height, but of course it will slope upwards. We have 10 foot high ceilings in our home so I think our enclosure is about 12 foot at the lowest because it matches the height of the roof on the back of the home.
