- Jun 4, 2020
- 27
- Fiberglass
- Pentair Intellichlor IC-30
Thanks ahead of time for any help as I am very new to this.
I recently installed a connection from my pump to my jet pump to keep water running through the jet pump in the winter and prevent freezing.
My pool has a built in spa. I run the spa on a schedule a few times a day in the winter to keep the water in those pipes from freezing.
With the new connection to the jet pump when the pool goes into spa mode it drains water from the spa into the pool as the connection is the path a least resistance. I have tried adjusting the ball vales for the jet pump connection and the pool/spa returns as well as the pump speeds to get things balanced to no avail.
I believe I need another valve and actuator on the connection to the jet pump so that when in spa mode this circuit closes.
Are there a maximum number of actuators certain sets will allow? Can I daisy chain to hook the additional actuators in series
