I have a 1 1/2” line that runs 20’ to the outside of my deck as an overflow. I believe this comes from a port on the skimmer box. Is it possible to use this 1 1/2” pipe outside the deck to install an Autofill from a plumbed water supply line?
No, because the 1.5" overflow line is located above the waterline.If the line is straight out of the skimmer to outside the pool deck can I add the auto fill outside in the same manner as if it was next to the pool?
An autofill needs to sense the level of the water, so it needs to be installed where pool water flows to it when the water is at normal levels.
If I understand what you are describing, then yes, you can install an overflow/autofill device in that line. I have the Paramount Paralevel, and really like it. It can be setup to handle both overflow and autofill.The 1 1/2” line is off the bottom of the skimmer box and runs outside the pool deck then up and out of the ground with a 90 at the desired water level. I was thinking g of digging down and cutting the pipe to install the autofill housing. Would that work and if so what autofill do you recommend?
Ah, well why didn't you say so!The 1 1/2” line is off the bottom of the skimmer box and runs outside the pool deck then up and out of the ground with a 90 at the desired water level. I was thinking g of digging down and cutting the pipe to install the autofill housing. Would that work and if so what autofill do you recommend?
