- May 11, 2021
- 36
- Plaster
- Jandy Truclear / Ei
Pool is almost done and now is the perfect time for me to lay any conduit since the yard is all ripped up. The back yard is about 60' wide by 38' depth. I have a covered patio that will house 2 x OSD AP650. I plan on putting 2 x OSD RS670 in the far back corner. The raise deck and spa are in the back corner and I figure I was mostly just going to use Bluetooth so I went with a Pyle PWA15BT that is rate at 100W / 40W RMS @ 4 OHM. This would be attached to an Pyle PVCS2 A/B speaker switch in case I just want the patio speakers on I figure that should be plenty of power for just 4 speakers. I plan on running speaker wire and CAT6 in 1" conduit with weatherproof double gang boxes.
I've attached a quick diagram I came up with as a guide. Of course $$$ is a factor since we just spent $$$$$ on the pool. Also, wife does not like it when we blast out the neighbors, I could care less.
Let me know any thoughts or opinions about the layout or equipment?
