The question is what do OZ people use for SWG and any specific comments on Eco Chlor RJ45 Salt Water Chlorinator | 100-180,000 Litre | 7-Year Warranty
The Zodiac LM3-40 is also on the short list
Happy to have advise though from the specialist here though on the general area of sizing
I have a Bestway 12x24 x 52 pool. I'm getting ready to move the current pump and filter to a new pad behind the garage about 20' away from the pool. the two outlets have already been enlarged for 2"/50mm plumbing.
I have a 21" sand filter and have just plumbed in a Pentair enviroMax 800 pump.
All piping will be 2" (50mm)
It seems like the logical time to plumb in a SWG and the larger the better
I realise the ones i'm looking at are considerable oversized based on the 2x rule but based on poolmath a 40 unit will allow me to generate all the chlorine i need in 3hrs max and likely less at 100 and easy meet needs at lower rates over the normal pump run times.
Current run times are around 11am to 6pm in summer as this aligns to my solar panel generation and allow most of the day skimming ... yep fully aware turnover is not relevant.
Thanks in advance
Phil
Thanks in advance
Phil
