Hi all, new here. gone through almost every pool service in my area and nearly impossible to find anyone who will maintain my pool properly and regularly.
Went to Leslie's pool and they advised me as they do everyone to use their tabs and dichlor. Guess what? Cya is at 150.
So here I am waiting for my test kit to arrive using test strips. (I know, I know I need a real test kit it's on its way ) Nearly drained my pool completely and it's nearly refilled now. I did a quick test to see what's needed. I see that I need to reduce pH,(7.8-8.4), fc at 0 and my cya is also zero.
I don't know my exact gallons, however using an estimating method of the average depth and length of perimeter I was able to estimate the gallons to be about 23,000. Using the pool calculator found here:
to bring my free chlorine up from 0 to 3 it says I need 88 oz of 10% bleach. I purchased a few gallons from home Depot and we'll add 11 cups of chlorine which is the converted amount for 88 Oz.
the color on the test strip is nearly impossible to distinguish but it's either 7.8 or 8.4 for my pH. The calculator says for my size pool I should add 36oz of Muriatic acid. I need to check the percentage on the bottle and will adjust in the calculator to confirm how much. I'm aiming for a 7.3 pH and I'm going to be conservative and assume at 7.8. if it's still high I'll add more acid.
So here's my question:
to bring my cya up from 0 to 30 the pool calculator is telling me I need to add 107 Oz of stabilizer which is about 6 and 1/2 lb. So my question is, does this seem like a lot of stabilizer? Home Depot sells 5 lb bags I can pick up to but draining the pool with the super slow pump and refilling this much water is expensive and time-consuming. So I just like to check with those who are much more experienced than I to make sure six pounds seems about right and is not excessive.
If anything I'm doing seems incorrect or if there's something else I should consider please let me know.
Sorry for the excessive length. I appreciate any assistance you can offer.
Thank you!
PoolMath
Discover the calculator behind the perfect pool, PoolMath. Dealing with pools has allowed TFP to become the original authors of the best calculator on the net.
www.troublefreepool.com
Thank you!
