Are pre opening test results accurate?
SUNOFTHEBEACH
95
Waldorf, MD
I have a mesh cover. Rain water and much dust and pollen pass through. I probably add/replace 1/4 of my water with rain water and snow.
my pool started turning green and I hit it with 2 gallons of 10 % bleach. The water looks clear, it’s cold and I can see dust covering the bottom.
I thrown in a little giant pump to move the water.
when I tested the water I got 3 ppm chlorine, 60 alk, 180 cal, and above 8 PH.
is there something about the above scenario that makes the PH read higher then it really is? Dead algae?
can I trust that reading?
should I add acid or wait until I open the pool clean it and retest?
ajw22
25,662
Northern NJ
Pentair Intellichlor IC-60
Wait until you open the pool to make any chemical adjustments. Water and chemicals can stratify when still. Get it well mixed before testing.
SUNOFTHEBEACH
95
Waldorf, MD
I jumped the gun and put some acid in there. My next PH test looked even darker red. Then I tested it with an uncalibrated PH meter that I just changed the batteries on and got a PH of 7.3
ajw22
25,662
Northern NJ
What is your FC?
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,518
You have a good test kit but I think you need to circulate the water better before you really rely on any test results
SUNOFTHEBEACH
95
Waldorf, MD
Just checked, my R0004 is just an old bottle that I emptied and refilled out of a 2 oz bottle that didn’t fit in my case. The 2 oz bottle expires 7/20 and has never been outside.
it would nice to know I’m getting alkaline water out of the tap though.
