Aquapure Output cable (R0512500) trouble
wantobpoolmaster
Active member
Jun 3, 2010
40
My output cable for my Aquapure EI SWG is having a problem connecting to the cell causing an Output Fault. The wires from the black input split apart. I tried to find a replacement part R0512500 but am finding that part has been discontinued. Is there a replacement part or do I have to fuse the wires to get it going. Any suggestions???
wantobpoolmaster
Active member
Jun 3, 2010
40
Unfortunately, every site I have gone to (approximately 10) say its discontinued and out of stock. Three even took my order only to get an e-mail that the order is canceled as they can not get the part. Even called Jandy and they also said part has been discontinued... I was hoping maybe they made a replacement part for that. I guess my options are repairing the wires that split or having to get a new SWG system...
wantobpoolmaster
Active member
Jun 3, 2010
40
I spliced the blue wire and black wire that get attached to the cell. When I wrap the black wire on the black terminal, I get a "No Flow". When I attached the Blue wire to the Blue terminal, I get an "Output Fault". Has anyone else seen this before? Thanks
wantobpoolmaster
Active member
Jun 3, 2010
40
Just an update for future reference. I replaced part R0512300 (Control Board) for $150 and the Output Fault display is now off. The SWG is producing Chlorine....
