Aquapure Jandy Salt Sensor Issue
Tommygarry1
Active member
May 16, 2021
32
New york
Hi all, I was having an issue with my salt cell sensor giving me erroneous salt readings and eventually not detecting flow. After looking at troubleshooting guides I decided to purchase a new sensor. I installed it and it worked great for 10 days, reading the salt accurately and detecting flow. All of a sudden, it stopped working and is it is detecting salt readings above 12000 PPM while giving me error codes 172 and 186. Any thoughts on this? Why would a sensor that was working perfectly fine and was brand new, pool company all of a sudden stop working ?
Tommygarry1
Active member
May 16, 2021
32
New york
No. My salt level is 3200 PPM as per my taykor kit. I haven't added salt as I don't need to at this time. Also. Whenever I add salt or any chemicals I throw in service mode to turn chkorinator off.
Tommygarry1
Active member
May 16, 2021
32
New york
Thanks for sharing. I read the whole manual. The only step left is change the sensor. But this is a new sensor. Some front boards have a testing mechanism but my board does not have that. Not sure what else to do. I did ask the company to send me a replacement
JamesW
32,437
On the Interface module, there are three LED's: one indicating flow, and two indicating firmware programs A & B.
1. Ensure there is power to the tri-sensor interface module.
Either PGM A or PGM B must be illuminated before proceeding.
If neither is illuminated, there is no power to the Tri-Sensor.
2. If the power interface board firmware is 02110A10 or 01220A15 as determined in Section B, 'PGM A' should be lit.
The firmware revision is printed on the CPU, which you can see in the picture.
It starts with "0211" and the rest is blocked by the cord.
It is probably 02110A10, which requires Program A.
