Hi,
Noticed my pool on routine test was at close to 0 chlorine. its been raining alot so figured it might be that, but when I looked at my cell, there were hardly any bubbles showing. Its a aftermarket clear cell. link to cell below. I do see some bubbles coming out of the returns in the pool like normal so I'm guessing its doing something just not much. I did all the troubleshooting per the manual on my board and everything was in spec except the output board voltage. It is reading 17 volts versus 22-28 volts. I have no error codes on the display. The question I have is before I order a new board as the troubleshooting instructions say, is it likely the board or could the cell be bad? I'm guessing the unit would throw a code if there was a problem with the cell itself? Is there anyway to definitely isolate one or the other? Board number is E0261700.
Edit: Cell was purchased April 17th 2023 so less than 4 months old.
www.poolsupplyunlimited.com
CompuPool 3-Port 14-Blade Replacement Salt Cell for Jandy AquaPure System | 40,000 Gallons | GRC/J40-3
CompuPool’s GRCJ14003, will work seamlessly with the 3 portJandy Aqua Pure 1400 (14 Blade) unit. OEM replacement salt cell also available.
