Aqualogic 0000 PPM salt and 0.0 amps
Apr 26, 2018
1
0
Suwanee
#1
My controller is telling me that I have no salt and I had it tested and it is around 4200ppm. When I go to diagnostics and turn the chlorinator on, it shows 0amps. I understand that the controller needs to have amps in order to properly read salt. Is there a way to test the voltage output to the cell. I am getting these same numbers with both an old cell and a brand new cell.
JamesW
12,661
3
#2
Maybe a damaged solder joint on the circuit board. Pull the board and look for a brown spot. Touch up any bad solder spots. Post a picture of the back of the circuit board if you don't see anything.
What is the voltage in diagnostics?
