Not sure if this is the right thread for this. My aqualink is controlling my aquapure just fine in pool mode, but in spa mode, it shows 00% even though it is set in the PDA.
NOTE The AquaLink RS control system must be in pool mode to change the pool chlorine production rate setting; and it must be in spa mode to change the spa chlorine production rate setting. Use the valve select button to switch between the two modes. The system must be cycled through SERVICE, TIME OUT, then back to AUTO to accept the Pool Setting versus the Spa Setting.
That appears to be speaking about setting the percentage at the unit as opposed to setting it on the PDA which I am doing.
yes, I set it in service mode last night but and left it for a bit, it showed the percentage on there, but didn't appear to make any chlorine based on my unscientific assumption that after an hour, my 600 gallon spa would be swimming with chlorine. I have called Jandy in the past and the answer is always call and authorized dealer
Its actually a 1400 series. It was just the water flowing through the spa. Test was already at around 5, relatively bright yellow so it should have started to turn orange/red, but it stayed yellow.
