Aquabright
RubiconValley
11
Portola Valley, CA
@bdavis466: You appear to be TFP's resident expert on Aquabright. Can you speak to whether it is advisable to forego waterline tile if using an Aquabright finish? (Also, if you will do work in CA 94028, I have a new-build 82'x12' pool I'd love for you to Aquabright!)
YippeeSkippy
17,100
Evans, Georgia
I don't want to speak for Bdavis, but I believe he's not doing pools any more from posts I've read here.
The aquabright finished pool pics I've seen seem to rarely add tile to the surface. I think tile added would diminish the beauty of the pool and finish.....just my opinion, of course.
Check the references of your chosen builder and ask to see other pools they've done aquabright on. This finish is very dependent on the skill of the applier.
Maddie :flower:
Reactions: RubiconValley
RubiconValley
11
Portola Valley, CA
Maddie :flower:
thank you!
swimcmp
In The Industry
Nov 8, 2011
1,091
Moberly,MO
Most Aquabright installers don't add tile since it wouldn't be flush like tile with a plaster finish. When we add tile it is done after the Aquabrite and we can use a silicone adhesive instead of a tile mastic that in my region allows tile mastic to draw moisture and pop tile off with freeze and thaw
RubiconValley
11
Portola Valley, CA
That makes sense--thank you =) I'm seeing not having to add waterline tile as a cost savings that helps mitigate the high cost of Aquabright!
