Aquabot turbo classic - pump motor oil
ooo
3
NJ
Hey all,
The other day I threw my aquabot turbo classic (unsure of year, 2011-current is what is on their part breakdown) and I noticed it was bubbling up some oil. It didn't look like motor oil, more like a mineral oil. Anyway, I pulled the pump motor out and noticed theres a top plug missing and I cannot find any information around the part number or what type of oil to replace it with.
A bit of background here - I left the bot on the side of the pool during a heatwave (110+ deg temps for a few days) so I'm guessing that lead to the pump motor overheating and popping the bung. The pump itself spins fine, definitely not seized up. I should just need to replace the oil and plug and be good to go. If I'm looking at spending $200 for a new pump I'm just going to invest in a new bot.
Any help here or links would be greatly appreciated - I cannot find anything on google around this, just replacement pump parts.
Pump part #: A6005
Aquabot Turbo Classic ~2011
ooo
3
NJ
(For anyone in the future who might be in a similar situation)
After reaching out to a few servicing places - it looks like once that plug is out the motor is done and needs to be replaced.
frogabog
2,833
Portland, Oregon
What is the plug intended to do?
A motor is (at it's basics) just windings and magnets. Why make a motor that needs a plug to seal in lubrication in the first place? No one is going to re-lube it.
JamesW
16,727
Motors like this that go under water are sometimes filled with a dielectric mineral oil that helps transfer heat from the motor to the water.
Many submersible pumps are also filled with oil.
The oil can be replaced but it's usually a life of motor product.
JamesW
16,727
It has to be the correct oil. It has to be non-conductive.
The plug makes some sense because you might need to service the motor, but it should be more secure so that it doesn't just pop out.
